SOURCE: defy laundromaid 1300 top loeaer shows an E9 when
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: I have a Defy
my laundromaid electro logic 920 is making unususl noise when rinsing!!
[email protected]
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are
the power IS OFF!
straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
SOURCE: Defy Laundromaid 1300 has a
I had the same problem. Defy technician came out paid him and found nothing wrong., leak never stopped. opened machine myself and found the inlet water solenoid laeking. bought the part from Defy R203.00 and the leak is fixed. Waisted my money with Def technician. Hope this will solve your problem
I have a Defy Laundromaid 1300. I was getting an E9 message.How can I solve this?
