SOURCE: Kenmore 417.948.62301 Stacked Washer / Dryer Problem
Pull the knob off the timer and you should see the screws that hold it in place. Access is from behind.
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
SOURCE: Kenmore stacked washer/dryer. Dryer runs fine but washer doesnt
push the knob in then turn it counter clockwise chek the lid switch it may be bad
SOURCE: how do i open washer of stack dryer washer to get
remove the angled panel between the washer and dryer, you will see either 3 or 4 screws holding the top of the washer in place or 2 gold colored clips. remove the screws(or clips) and the top should slide forward and come off. this gives you access to the screws holding the front in place.
