1999 Chrysler Town & Country Logo
Darleen Wilson Posted on Apr 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What would cause my 1999 town & country not to move in any gear
My van won't move at all in any gear. from park to reverse u can feel it shift but wont move from park to drive or reverse to drive u cant hear it shift still wont move, I hit gas it made a loud noise then a hard **** then barely moved and that was it
  • Theodore Trujillo Apr 11, 2014
    Sorry to say but you need to rebuild the transmission.......... same thing happened to me when ine went out
  • Anonymous Apr 11, 2014
    UnforUnfortunately, ala Gordon Ramsey, it is how they say, "cooked."? But before you do anything ask around, or look up on line for some really good repair shops that do not do transmissions. Ask who they recommend. Ask if they know any race car mechanics. Ask them who does their transmissions. I did that and got a shop that did an outstanding job. It cost me $3000. But, if you buy a junk yard tranny, even with a guarantee, you have to pay labor to put it in, then take it out if it fails. That is a real risk. A good shop will test your engine first. If your engine is in good shape and you arre satisfied with the rest of the car, then a transmission will last you at least 100K. I had 170K on the first one, replaced it and have 85K on the new one. Some shops like mine will even come pick your car up for free or for less than you'd pay a tow truck. You are still looking at a sizeable sum so its is worth considering the cost.
Hector L. Morales
Level 3:
  • Chrysler Master 649 Answers
  • Posted on Apr 11, 2014
Hector L. Morales
Chrysler Master
Level 3:
Answers
649
Questions
0
Helped
243261
Points
1923
Make sure that your axles aren't broken. If you have a broken axle the power would transfer to the wheel with the least amount of resistance (to the broken axle) therefore not propelling the vehicle. Also look at your fluid level and condition. It is possible that the transmission is slipping in which case you'd need a transmission/rebuild.
2 Related Answers
Anonymous
  • 44 Answers
  • Posted on May 28, 2008
SOURCE: shifts into gear roughly
the pin in the differential inside the trans probably came out. you need a new transmission since this usually causes major case damage.
skychief2001
Stephen
  • 21873 Answers
  • Posted on Jul 31, 2012
SOURCE: 1998 Chrysler town and country wont shift into drive
Is the check engine light on ?
You may have a problem with a solenoid or pressure problem in the transaxle.
What stops my transmission from going into gear?
your tranny is shot,like most chrysler vans,the tranny sucks,1200 to fix,junk it
98 Chrysler Town & Country Ignition, steering wheel & gear shift are all locked up. Last night we stopped to get some fast food. When we came back out to the van, it would not allow us to move...
Sometimes the mechanical system that locks your steering wheel has too much vehicle weight which can prevent the key from turning. If you can move the vehicle back and forth while someone turn the steering wheel and turn the ignition switch.
2001 town and country engine light on will not go into drive or reverse plenty of fluid
Does it feel like its even shifting when you move the shifter,Check under hood to see if the shift cable broke or came out of its retainer.
Won't shift out of second gear
There are a couple of videos on youtube where people solved the same problem by replacing
the input speed sensor Costs about $30.00 for part.
Maybe this would help?
I am not a mechanic but I have same problem and am trying to get to the bottom of it
May 1996 van has been doing the same thing for a couple years. It will then sometimes
shift into 3rd gear after driving awhile.
Unfortunately my van is now stuck in driveway in reverse so I cant even start it
Regards, Paul
98 twn and country van trans slips into reverse and first gear when its cold. Is there a simple fixx
There is probably a problem with the cable and/or cable connection/shifting bracket to the transmission. It is located on the top of the transmission. With a Partner: have them turn the key to the on (not start) position and have them shift to each of the PRNDL positions.
Meanwhile YOU: Inspect that area to ensure nothing is impeding the cable/cable connection/shifting bracket, or interfering their operation.
When shifting, is the Indicator "on" or to the left or right of the appropriate selection (PRNDL)? If the indicator is to the left or right of them there is a good possibility that you need to loosen the gear cable connection, located on top of the transmission and pull the shifting bracket going into the transmission - towards the front of the car. While holding the bracket to the front (Park) position tighten back down the cable fasteners.
Let me know if this helped, or if you have additional questions or information. Feel free to contact me at FixYa.com!
9helpful
2answers
Where is the neutral safety switch located on 1998 Town & Country
It is built into the valve body of the transmission. It can be replaced, but it should be done by a pro. What are the symtoms that make you ask>
2helpful
Transmission still shifts erractically
well if you have a lot of millage it could only be the gearpump in the transy thats finished,unfotuntly ...you cant really change -it without rebuilding the all transy
other than that you still can drive-it but try letting the gear go on by it self ,you could damage your van by doing that !! you mignt not have choice but if you do ...try not doing-it!
4helpful
Gear shift won't move out of park sometimes
look for transmission shift interlock solenoid fuse.or a bad brake switch will cause transmission not to come out of park.
A chattering noise appears when I put the transmission in gear
Sounds like a worn/bad/damage transmisison or engine mount. These hold the engine and trans in place and usually have a rubber part that can wear out.
Either a trans shop or regular mechanic will need to diagnose.
I don't know the cost.
GL,
TD
Shifts into gear roughly
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
