Kodak EasyShare Z915 Digital Camera Logo
A
Anonymous Posted on Apr 10, 2014
How to reset month/day/year on camera
I need to know how to reset the month day and year on my camera so pictures will show the accurate date on the pictures when they are taken
1 Related Answer
seofelite
Jonathan
  • 114 Answers
  • Posted on Jun 30, 2010
SOURCE: The date doesn't print on the picture
Found the manual for your camera in PDF format, here's the link:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01024/M341_xUG_GLB_en.pdf
It's on page 20 in the manual. Hope this was what you were looking for :)
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
How do I set camera to print date on each picture I take?
This will only work in postcard resolution. See pages 35 and 36 of the user manual at this link.
Need to change the date of previous taken pictures
load the pictures to an computer and click on characteristic trait
and rename the date
Grainy pictures
There are many settings which may have been accidentally changed. I suggest that the easiest way for you to go back the factory settings would be to use the "reset" facility on the menu options. This will reset the camera to the way it was when it came from the factory. Following this, you may need to reset the date and time. Alternatively, you can leave the batteries out of the camera for a few days, and this will cause it to lose any settings, forcing a factory reset.
How do I set the time on an Olympus c-725 Camera?
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
10helpful
Setting date & time on M7310
Normal 0 TIME CHANGE PROCEDURE: DONE FROM THE MAINPHONE
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will shoe hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
let me know how you get on
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
3helpful
Vivitar 3720 digital camera
,,,push the "square" button in the middle of the direction arrows.
..press the right arrow across untill you come to Date and Time
...press the down arrow to select the "set" and press the square button again
....use the up and down arrows to select the correct date
....use the right arrow button to set the month and day and so on.....
Also, if you don't want the time displayed on the picture, just select "no display".
I hope this helps!
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
