How do I restore the factory settings on a HP 1050 printer?
SOURCE: keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
SOURCE: HP PSC 2410 All-In-One InkJet printer default settings
Please can i obtain advice on how to reset my printer, as i am getting funny noises from it and nothing else.
SOURCE: HP PSC 1410 All in one printer
Reset the HP All-in-OneFollow the steps below to reset the All-in-One.
SOURCE: i have a printer hp
Solution: Delete the printer error icon, and then install the HP software
Follow these steps to remove the printer error icon, and then install the HP software.
Step one: Delete the printer error icon
Follow these steps to remove the printer error icon from your list of devices and printers.
Step two: Install the product software
Use the following methods to install the HP software with a USB connection.
Figure 1: USB cable
CAUTION:
Do NOT connect the USB cable now. Wait until the on-screen instructions prompt you to connect it. HP recommends using a USB cable that is less than 3 m (10 ft) long.
Should I install with the product CD or download the software?
Don't worry if you don't have the product CD! You can download the most current software available for your product from the HP Web site at no cost. The following information might help you decide which installation method to use:
CD
Download
The CD provides a quick and easy installation method.
If you do not have a CD, you can download the software you need from the HP Web site.
CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released.
Even though it takes more time than using the CD, downloading the latest software can help avoid installation issues.
Downloading is the recommended method if your computer operating system released after the HP product released.
The software on the CD is current to the date of the product release.
The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market.
Step one: Download the software
Follow these steps to download the product software and save it to your computer.
Step two: Install the software
During the installation, the Basic Device Software and Product Help are required to enable full product functionality. HP also includes valuable software to help you get the most out of your product.
Follow these steps to install the downloaded software.
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
