SOURCE: Model 760 H projector-- Carrousel advances, but slides do not
My guess is that your slides are in a 140-slide tray.
Over time, with repeated cycles of humidity & drying, slides warp slightly. The compartment width in a 140-slide tray is quite narrow, and it takes very little warping to make slides stick in their individual compartments. If you move the slides to a KODAK 80 Slide Tray you should be in much better shape.
SOURCE: Kodak 750H corousel slide projector
Chances are, by your description (and my estimate of the age of this model of projector), that you have a broken solenoid "link". The "link" connects the cycle solenoid and the slide change mechanism. The "link" is made of plastic, and gets brittle & cracks over time. This is a difficult repair, but you should still be able to find parts available. My advice is have this repair done by a factory-trained repair dealer and your projector will run another 20 years.
SOURCE: No manual or remote advance on kodak 35mm carosel
You didn't specify the model, but chances are that the cycling problem is caused by a broken "link". The "link" connects the cycle solenoid plunger to the slide change mechanism. The "link" is made of plastic, and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair requiring disassembly & a service manual - - best left to a factory-trained repair dealer.
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
