Sewing Machines Logo
N
Nancy Kimble Posted on Mar 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please explain knit stitch one row under
I have a pattern that says insert needle in next stitch in row below
Anne Croucher
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Oct 31, 2014
Anne Croucher
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
3952
Points
39
This is a clumsy way of knitting a tucked stitch - the writer of the pattern is ignorant of the way it is done properly. The writer wants you to knit a stitch, then on the next row rather than knitting in the usual way you insert the needle into the stitch on the row below and so making the stitch on the needle was a waste of your time. If the stitch is fisherman's rib, for each purl stitch you need only bring the yarn to the front and then slip the stitch to the other needle. Take the yarn to the back over the top of the needle so making a bridge over the slipped stitch. Knit the next stitch. Then on the next row you knit the stitch and the bridge of yarn together. This is much faster than the knit into the stitch below method and produces a nicer more even rib structure.
chizaram agwamba
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 174 Answers
  • Posted on Mar 26, 2014
chizaram agwamba
Expert
Level 2:
New Friend:
Cheetah:
Answers
174
Questions
Helped
14162
Points
319
Ask in another area
I have 147 stitches left on needle in knitting a sweater,pattern says to knit 2 together across row and have 75 stitches on needle how is that possible?????
Either you messed up or whoever wrote instructions messed up. You'd have to have 150 stitches to end up with 75. Unfortunately, I think that you lost a few stitches somewhere. This is why I don't knit anymore. :)
What does yarn round needle lol like
It means an increase or a lace stitch. You put the yarn in front of the needle instead of the back when you knit. This makes a hole and adds a stitch. The next row you usually knit 2 stitches together to combat this. Buy without actually seeing the pattern it' could have a different answer. :-)
1helpful
I'm knitting the Irish moss stitch in the round and I can't figure out how to decrease the stitches while keeping the pattern.
Probaly have thrown the knittig away by now, but for future reference. If the decreasesare at the end of a row, you will be able to keep th sequence on the next row, if it's in the middle of a row, it's a bit more tricky, you just have to concentrate and match the pattern. I know you will be able to see the decrease, but this is unavoidable if t's in the middle of a row, but at the end of a row or round just follow the pattern, as you would, being careful to match stitches. It's difficult to tell, rather than show. Have you tried to Google it? There may be a video. Good luck. :-)
I am also having a problem with the Chick baby pattern. It says yfd k2, SY2K, k1. Please explain.
Is it a lace pattern or are you making holes for a ribbon etc. :-) Ok, yfd, means yarn in front of your right hand needle. then K2 (knit 2 sts)then SY2k (slip yarn then knit 2)
I would really like to know what the next row of pattern says. Because the SYK@ is a bit ambiguous without seeing the full pattern.
Please show the knitting term ssk with illustrations?
can't give you illustrations but. SSK means slip stitch knit. Which means slip the next stitch onto the needle as though you will knit it then knit the next stitch instead keeping the slipped stitch on the needle and go ahead and finish the row.
How should the first stich in each row be knitted. I.e opposite of what the pattern calls for or pulled off Thank you.
The first stitch of the row is usually the chain that you ended in the last row. The chain essentially builds the height of the pattern to the next row so the stitches are even height from beginning to end. After you have made the chain, then begin with the first stitch in the next row pattern.
So, if the pattern says to knit 3 (or purl 3), that 3 stitches allows the height for the next row.
The pattern says s1, k1,ym, k2tog, knit to end of row.
S1 = slip next stitch
K1 = knit one
YRN = Yarn Over (not YM!)
K2tog = knit 2 stitches together
Knit to end of row
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Can you please explain further what this knitting abbreviation means k3to7= knit 3 sts together w/o dropping them of the needle, yo, repeat 2 more times, knit 3 sts together once more, slip sts off the...
It looks like you would scoop up three stitches instead of one and then instead of transferring them over to the other needle you would yarn over and repeat that action twice more, then scoop up three stitches knit and count how many stitches you have if you do it right you have increased the row from 3 stitches to 7.
Try and see if it looks right. Bill in Oregon
2answers
What does knit over mean
Read the pattern again. You may be doing short rows. Buy a more detail knitting book. If you can go to Knit and Crochet Today it's a tv show that has a website they have experts in knitting and crocheting. Sure there is a demo or someone you can ask to explain in detail. I think the show comes on Thursday in Chicago but its once a week on cable/satellite on pbs.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
