Starts noise at 30mph getting very loud sometimes rumbles has new brakes hard to spin rear wheels up on jack and in neutral gear has 4wheel steering i think dana rear
Run vehicle while on hoist/Listen w/Stethoscope.....Sometimes the 'sound' travels throughout the drive train components & can be tough to pinpoint...Time for a pro !!
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
SOURCE: Clunk noise from rear of truck
How about the U joint? If it's shot, you will hear a clunk when u start up. You probably already know, but jack up the back of the truck (both wheels off the ground) make sure u blocked front wheels front and back so it can't roll, use jack stands so u don't get squished, truck in neutral, e- brake off, climb under, grab driveshaft and twist back and forth to see if there is slop or play in the rear universal joint. Let me know what u find. Good Luck, and don't get squished (or squashed). countrycurt0
SOURCE: Squeaky sound front left tire and 4Wheel Drive will not turn on
the squeak could be brakes or wheel hub/bearing. most likely it is the bearing and hub assembly, i would not drive it , take it to you local service station and have then replace or repair the hub assy.
SOURCE: right rear wheel locking up
okay you had brake work done!!! "THINKING" that was the problem originally right rear wheel locking up! okay,,, so doing brakes has not solved your problem! I would maybe look into rear end bearing??? do you have any load road noise from rear and do you have rear end fluid in differential? question to you was the baking plate ""WET"" looked damp? or moister get at it!??? seal might have leaked all fluid out??? all the above would be good place to start! good luck I hope this info helps you out.Happy new year.
SOURCE: 2004gmc 4wheel drive front wheel bearing replacement
Check your brake pads your probably into the rotors
SOURCE: 1998 GMC JIMMY 4 WHEEL DRIVE, NOISE COMING FROM FRONT WHEEL AREA
it is the u joints on the front drive shaft ,i had the same problem and like too never found it!!!
