Lands Phones Logo
a
andrea cristallo Posted on Mar 25, 2014
Telstra v580a handset register
Cant register to base
1 Related Answer
Anonymous
  • Posted on Oct 23, 2010
SOURCE: Unregistered Telstra V580a handsets
same problem here T.T really urgent
Telstra cordless 301 message light flashes on handset 1 which is on the base, but the 2nd handset message light does not flash even if it is on the cradle. I have unplugged both phones several times to no...
If the message light on the Telstra cordless handset 1 is flashing, indicating a new message, but the message light on handset 2 does not flash even when it's on the cradle, there are a few troubleshooting steps you can try:
  1. Check message notification settings: Make sure that the message notification settings on both handsets are properly configured. Refer to the user manual or the settings menu on the handsets to adjust the message notification settings. Ensure that the notification is enabled for both handsets.
  2. Reset the handsets: Try resetting both handsets to their default settings. This can be done by removing the batteries from the handsets, unplugging the base station, and leaving them disconnected for a few minutes. Then, reinsert the batteries and plug in the base station. Allow the handsets to reconnect to the base and check if the message light on both handsets functions properly.
  3. Check the base station: Ensure that the base station is functioning correctly. Check if the base station is properly connected to the telephone line and power source. If possible, try connecting handset 2 to the base station that handset 1 is connected to and see if the message light functions on that base station. This will help determine if the issue is with the base station or the handset itself.
  4. Contact Telstra support: If the issue persists after trying the above steps, it may be best to contact Telstra support directly for further assistance. They will have specific knowledge of their product and can provide more detailed troubleshooting steps or advise on any potential repairs or replacements that may be necessary.
Remember to refer to the user manual for your specific Telstra cordless model for more detailed instructions on troubleshooting and operating the handset.
1helpful
I have a Telstra V580a with two other handsets. One of the handsets does not have any display. Have replaced the battery, but no change. Solution? fred
Replace the handset, the cost to replace it is less than the cost of repair if they even sell parts which I doubt.
How do I add a handset to a Telstra V580A cordless phone system
Here is the manual:
http://www.telstra.com.au/help/download/document/telstra-v580a-290409.pdf
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Registering a handset
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
2helpful
Need replacement manual for Telstra Cordless model V580a+1
http://www.telstra.com.au/help/download/document/telstra-v580a-290409.pdf?red=/help/docs/telstra-v580a-290409.pdf
1helpful
4helpful
Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
Top Siemens Lands Phones Experts
Kolbrun...
 Mikey
Mikey
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
