Car wont start have replaced starter motor and relay and igniyion switch still wont start
What is year--make--model?
Make sure battery has a full charge and battery connections are all good. If your saying starter motor won't crank, check voltage and ground at the starter motor. Usually two voltage circuits at the starter, one comes from the battery, hot all the time. The other circuit goes hot with key in the crank position and in your case, I suppose wired through the starter relay. The relay has two circuits, the load side and control side of relay. The control side of relay needs voltage and ground to energize the relay. The load side of relay, in a diagram shows a line with arrowhead, when relay is energized, that arrowhead line moves to other terminal and that circuit carries voltage to starter. The voltage for load side of relay is usually hot all the time. I can't rule out neutral or clutch switch. The starter motor usually grounds through the engine block. If all voltage and ground circuit for the starter are good, I'd have to make sure the engine isn't seized.
Any testing at the starter, make sure tranny is in park or neutral and functional parking brake is set.
