Computers & Internet Logo
A
Anonymous Posted on Mar 18, 2014
Psdcodecpreferences psd codec 1.6.1.0 serial name and serial number
2helpful
2answers
I need a n264 codec to play cctv footage
You have to uninstall other codec packs.
Try the K-Lite Mega Codec pack.
Maybe it is H264? THe VLC player or the Media Player Classic can play those videos on their own.
tip
Nokia_Mobile_Secret_Codes
*#06# IMEI
*#0000# view Software Version
*#746025625# [*#sim0clock#]
*#92702689# [*#war0anty#] secret menu:
1. Displays Serial Number
2. Displays the Month and Year of Manufacture (0997)
3. Displays (if there) the date where the phone was purchased
4. Displays the date of last repairment - if found (0000)
5. Makes you capebel of transferring user data
6. Shows how many hours the phone has been on
*3370# Enhanced Full Rate Codec (EFR) activation
#3370# Enhanced Full Rate Codec (EFR) deactivation
*4370# Half Rate Codec activation
#4370# Half Rate Codec deactivation
xx# - xx position in Phone Book
NOKIA 9000
*#06# IMEI
*#682371158412125# soft version
*#3283# prod. date
NOKIA 7650
*#7979# phone reset
*#7470# hard reset
*#7370# master reset (like new phone)
No audio devices
Hello visit the mainboards homepage here:
http://www.mercury-pc.com/downloads.php
And download the drivers needed, by entering the mainboard number.
Or select the model manualy.
Or visit intel here:
http://downloadcenter.intel.com/
And run the update utility.
Good luck
13helpful
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
1helpful
I need to know kilowatt of fire - serial number
3412.1416 btus = 1 kilowatt , so it should have the btus near the serial number , but with no name or model number , thats all you can do
Driver provlem
Is it possible it's a Sound Blaster Audigy?
http://www-307.ibm.com/pc/support/site.wss/MIGR-51794.html
Hope this helps!
1helpful
2answers
Where can i get the sound driver for my motherboard intel d865gkd
The sound driver you need is the SoundMAX Cadenza driver. according
IBM YOUR IS http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51191&velxr-layout=printLenovo
Thank you.
1helpful
Videos on HTC HD not playing smooth
Try coreplayer. It plays most media without issue - its $29 though. The serial number they provide is tied in with the owner/device name so cracked versions with a serial number must also have a owner name supplied or it won't work.
This software has fixed my playback issues.
6helpful
2answers
Top Ardfry Imaging Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Ardfry Imaging Computer and Internet Expert? Answer questions, earn points and help others
