Shark VX2 Cordless Sweeper, V1945Z Logo
A
Anonymous Posted on Mar 10, 2014
Charger for V1945ZN?
Need charger
1helpful
I need a charger for my Dust Buster.
You don't need an actual charger that says Dust Buster on it. You can use any charger of the same voltage from some other gadget. Most are 9 volt. Not all, but many are. Just look on the dust buster tag & see what it requires. Some stores like Radio Shack even sell the charger with several adapters..One sure to fit your Dust Buster. Good Luck. This is a pic of one that is $13 at Walmart.
Apr 05, 2018 • Vacuums
2helpful
2answers
Is charger not working?
If you have a DC voltmeter and can see the contacts in the charger, you may be able to see it the charger has a output. But with the newer electronics for battery charging, the battery may need to be in the charger to get a reading. My guess is you do have a bad charger.
Can I buy a charger?
You need to get the make, model number and check online for local parts distributor or contact the Manufacturer direct. If you cant get one, check what voltage is on its input and output. There may be a specialist electronics store that has a "generic" charger which will work.
Jul 01, 2015 • Vacuums
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
The red light keeps blinking while I have the charger plugged in, is this normal?
Hi! If the light on the charger is blinking this can mean an issue with your charger adaptor. Check that the charger is still warm. If so, unplug the charger for a few minutes and plug it back in. If the light is still blinking your charger adaptor may need to be replaced. Hope this helps!
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Can I get a charger for a powerbase screwdriver? I've lost mine. Jacqui
Find out what voltage is required for the charger and any universal charger with a compatible connector will work. Batteries are rated at 1.2 volts, so if the screwdriver has 3 batteries you need a charger that delivers about 4 volts. A good hardware store should be able to supply you with a suitable charger.
Jan 17, 2011 • Vacuums
Lights on charger do not light and therfore do not charge roomba.
If the charger doesn't light up, it's broken.
Call customer support at 1-877-855-8593. Be sure to have the Roomba and charger with you when you call-- you'll need them.
2helpful
NEED CHARGER MOD:HHD20-200
I have same problem. Please post it if you find source of battery charger HHD-20-200.
Apr 18, 2009 • Vacuums
Top Shark Vacuums Experts
vince
Paul Carew
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
