Perhaps you only changed the settings. As long as you are on automatic, and don't force the flash off, the flash should work when needed.
The multiple flash you mention, is the flash used to avoid red eyes.
With the first flash(es) the eye closes the pupil, so ref;action of the retina is minimal.
Sometimes the camera also uses the returning flash light to fine tune the focus, if on auto focus.
Just check if the camera is in the setting you always used. Just check if you have the best results with this setting.
Testimonial: "Thanks for answer, but today flash is not working even if I choose "Flash always on" settings, Nothing happened on any settings. I tried to restore factory defaults, same result. No flash on any settings."
SOURCE: DSC-P72 using Flash
hello everybody, This is a general issue, even with red-eye off, even with AF illuminator off,there is a pre-flash just before the main flash which can close some people's eyes. It can't be offed. How to do? If your cam has a shoe, you can use an external flash which strobes only once!
SOURCE: Pictures too bright
cover the lens with your hand - if the pix is still bright ? the ccd may be failing ( your dock / computer connection will help in seeing this low light level test ) and if so , parts availability will be your next test ;
