20 Most Recent Nikon COOLPIX L100 Digital Camera Questions & Answers
Is this information not contained in the manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Nikon COOLPIX... | Answered on Feb 21, 2017
look at the lens and ensure there is no dirt - fingerprint etc on the lens. Otherwise, it is time to visit your local camera store.
Nikon COOLPIX... | Answered on May 17, 2016
the mother board comes faulty, check the battery contact for corrosion, clean it.
Nikon COOLPIX... | Answered on Feb 01, 2016
You must have dropped the camera or hit it . If it is the case you probably bent the casiing the will prevent the camera to function.
Nikon COOLPIX... | Answered on Jan 26, 2016
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
Nikon COOLPIX... | Answered on Nov 16, 2015
You will need a photo editing softwares! There are loads to choose from it depends on your budget and how much you want to spend! Most offer free trials, so take your pick and get testing!
Nikon COOLPIX... | Answered on Nov 14, 2014
Check the menu....ensure B&W option is not selected..
Nikon COOLPIX... | Answered on Oct 15, 2014
Nikon COOLPIX L100 Digital Camera, go to Nikon.com, they should be able to get another disk to you good luck.
Nikon COOLPIX... | Answered on May 25, 2014
Nikon COOLPIX L100 Digital Camera Logo
196 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
white background not white
  • Cameras
