The audio icon on the tray is showing with a cross sign, and an error message is showing indicating ''No Audio Output Device is Installed''. How can I fix it?
SOURCE: my computer cannot detect multimedia audio controller
Download Microsoft UAA driver then install it
Uninstall any sound driver first then
Go to device drivers and update your sound driver will go on net and find them and install them
SOURCE: installation of audio output device
Hi there install a sound card again to your laptop.........then it will be okay...
SOURCE: NO VISTA AUDIO DRIVER FOR ASUS P5GL-MX MOTHERBOARD
First off, go into BIOS at boot (hold del key) and make sure that your onboard sound is switched on.
Then check your device manager (control panel/device manager) to see if it identifies your sound chip.
Use right click/update driver/search online to see if microsoft can find it for you. If not, it is very likely a Realtek AC97 chip or similar. Search for this driver and go on from there.
SOURCE: No Audio Output Device is
This is Intel's link for downloads, however, your board does not seem to have support past Win XP, if you have upgraded to Vista or Windows 7, you are probably expieriencing compatabilty problems between the older software:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+845+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D845GVSR
You have Realtek ALC202A with AC97 codec for sound so you can try here:
http://www.realtek.com.tw/downloads/
Make sure you go to your device manager and check in "sound, Audio and game controllers", to make sure you device is "enabled".
SOURCE: i need the audio output
if your computer came with a motherboard disc the sound drivers could be on it http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html Download the driver software by http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers using this link you will be able select your drivers hope this helps
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disc you will have to download the drivers
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
hope this helps
Update your embedded sound from Realtek to the latest AC'97 codec.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
