KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
s
simon abbott Posted on Mar 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you take a 5k5m150 apart - KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Mar 02, 2014
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
583523
Points
2445
Tap drip ring off, punch out pin through planetary. Remove back cover, unclip black wire and white wire from rear control board. Tip it upside down, remove pedestal. Undo 5 screws around where planetary came from, undo the remaining 4 screws on underside of gear case, pull the cases apart.
How to take apart Hobart A200 shifter/speed unit.
Here is the Technical Manual
https://www.partstown.com/modelManual/HOB-A200_spm.pdf
Repair help and videos.
https://www.google.com/search?q=hobart+a200+repair
Hobart A200 Restoration
The Fresh Loaf https://www.thefreshloaf.com > node > a200-restoration
Mar 8, 2020 - I'm currently disassembling my A200 and I can't seem to get the planetary to just slide off like the videos seem to show. Am I missing something ...
My Hobart A200 rebuild
The Fresh Loaf https://www.thefreshloaf.com > node > my-hobart-a200-...
Oct 21, 2021 - So I took it completely apart, cleaned and degreased it inside and out, stripped the old paint, replaced the worn parts (power cable, bearings ...
How can I take a Varimixer W5A Teddy Mixer apart... My Mixer will not move and to find the error I would like to take it apart.
https://www.partstown.com/varimixer/w5a/parts?page=0 this should help you, good luck and remember to unplug it first!!
My husband dropped my KitchenAid mixer in the sink, and when it landed, it bent and jammed up the lever that changes the speed and turns it on. Now, it won't turn on at all.
"Tried to take it apart" seems to indicate that you didn't get it apart. If you want to straighten the lever properly that's the only way you are going to get it straight. If there are any other problems they will be revealed during the taking apart process. Back off, pedestal off, planetary off and split the cases.
Kitchen aid unlocks
By unlocks I have to assume that the mixer head can be lifted up during operation (yes that's really messy ans in some cases maybe even dangerous) I have to assume that you also mean the the head lock switch is not engaging, You have to take the mixer apart to re attach the mixer lock switch. There are several really good videos on youtube that shows step by step procedure for taking the mixer apart. you will see the switch when you have the mixer apart. tighten the screw down tight enough to make the switch engage again. Re-assemble the mixer.
1helpful
The speed lever on my KSM 90 won't lock in the off position.
Do you have a manual? You can download one from Kitchen Aid, small appliances. There should be a schematic and how to that will help.
Trying to take apart the hamilton beach stand mixer to fix it
There should be a few screws on the underside that will allow you to remove the top. You may have to take the head off the base to do this.
The hand mixer won't work
if you can take it apart easy and not break any part of it and remember exactly how it was then yes. but you can get a new hand mixer for 10 bucks.
Jan 01, 2009 • Food Mixers
Kitchenaide mixer model KHM3WH-1
You can see the parts breakdown HERE. It looks like there are 3 screws on the bottom...
Aug 09, 2008 • Food Mixers
3helpful
Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
