Blah blah blah blah locked out of bios,keyboard kl==locked, wont go to settings (f2,f12) and such i cant type anything (nothing is wrong with the keyboard)
You need to remove the cover of the laptop locate the password jumper.(near the hard drive, clearly labelled.) take what looks like a little cap off. push the power on button for three seconds. replace cap close laptop, replace cover, and your password will be reset. leave it blank, do not do this with laptop a/c power cord plug into wall socket.
SOURCE: i have a dell inspiron 6400...will not boot..tried
Windows is corrupted you will have to use your Dell Restore Cd to reinstall Windows.The drivers if you have the driver cd will have to be reinstalled as well.
Good Luck
SOURCE: my dell inspiron 1501 is stuck in bios about 75%
operating system isnt loading....try booting with a windows boot cd
SOURCE: unresponsive keyboard
Replace the keyboard. They're readily available on ebay. Also, try plugging a usb keyboard in & see if it still happens. If it does then forget replacing the keyboard. Instead you'll be needing a motherboard.
SOURCE: Dell laptop ... inspiron 6400 System/adminstrator password
I believed this can be resolve by clean the cmos battery. you need to remove the cmos batery from the laptop then power it on then immediately turn it off. then put the battery back to the laptop then power it on keep tapping on f2 to enter setup. please follow the instructions from the link to remove the cmos battery http://tinyurl.com/yb3mhyg
SOURCE: dell inspiron 1525 invalid password bios
don't mess with short circuiting, dellpasswords.com
have dell bios password from dell with older and newer bios password
just require both passwords from them,
as you noticed dell have now 2 bios password depending on the bios version, usually A9 - 2011
