Comfort-Aire HMC18AD-1 Air Conditioner Logo
M
Miguel Vinculado Posted on Feb 20, 2014
Wiring diagram of LG split type aicondition model LSC242TMBO
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
1helpful
Lg split airconditioner model LSN 364H-1 has fault 5 flashes please advise what this means
Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.Thanks.
LG split inverter model LSL122V3 and it doesn't cool and shuts down after a few minutes with the green led flashing five times repeating.
Communcation error between in and out.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
1helpful
Wiring diagram
Get it with
www.lg.com/in/air-conditioning/index.jsp
1.i want to know electical wiring diagram of split type air conditioner
contact lg for that they will suppy u with it. fairly simple system. describe ur issue
1helpful
2answers
4answers
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Top Comfort-Aire Heating & Cooling Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Arnie Burke
Arnie Burke
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
