Sanyo  Split System Air Conditioner
Problems with Sanyo Split System Air Conditioner?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Sanyo  Split System Air Conditioner RSS Feed
Click here to get instant support from our best Experts!
View More Results for Sanyo Split System Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Sanyo  Split System Air Conditioner RSS Feed
Answer
Need wireless remote control RCS-KS-1 for Unit PKE-K250AS6A
Answer
how to run sanyo heat and cool model. i want to run it for heating purpose.
Answer
model ks1853 serial 0008941 low speed fan only.
Answer
is there a height limitation between the two units ie can the condenser be 20 feet or so below the... (More)
Answer
wall sensor seems to be responding to remote controller, but the main board is not responding to... (More)
Answer
I'm looking for a sanyo remote control for my ac with the number RCS-2HS4E
Answer
We have a Sanyo KHS0921 that the system monitor lights show over load. What should we look for?
Find a Manual
Sanyo Split System Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Does your A/C coil freeze up?
This is actually something that causes more service calls than actual failures. Those who do not have the knowledge to fix it has to make that dreaded... written by cj2176
You can add Air Conditioning to Your Hot Air Furnace
Air Conditioning is easier to add to an existing central hot air heating system then you might think. Both systems use air to move the heating or... written by heatman101
Old motor has 3 wires, new motor has 4 wires, WTF?
You always want to save a few bucks in these tough times right? Don't want to spend a fortune replacing the motor with the exactamundo. So you... written by TheMobilian
Some central air conditioning unit solutions
outside works inside don't Nothing works Outside quit inside works written by TheMobilian
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow... written by heatman101
How to Keep House Cool Without Using Air Conditioning
The expense of running the air conditioner is just too much. You open the house doors and windows up to try to cool the house down. But the house just... written by heatman101
outside unit fan replacement tip
Your central unit outside condenser motor is gonna someday die, that's a fact of life, will you pay some guy 450 dollars to replace a 75 dollar part?... written by TheMobilian
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central... written by heatman101
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Sanyo Split System Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Ratings for the Sanyo Split System Air Conditioner
Owners Recommend
out of 2
Reliability
Ease of use
Value for Money
Rate and Review the Sanyo Split System Air Conditioner
Write a review:
Rate this product:
Would you recommend the Split System Air Conditioner to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Sanyo Split System Air Conditioner
Key Features
Remote Control
With Remote Control
Energy Efficiency Rating
16 EER
Fan Speeds (Cooling)
AC Type
Split System
Other Features
Moisture Removal (Pt/h)
4.89
Filter
Reusable
Air Flow
524 CFM
Swing Louvers
Auto-swing
Dimensions
Depth
8.59 in.
Height
11.72 in.
Width
41.94 in.
Electrical Requirements
Voltage
208 / 230
Cooling Ampacity
7 / 7.7
Cooling Watts
1500 / 1500
Product MPN
MPN
18KLS72
Supported Models
18KLS72
Sanyo Contact Information
Main support number(800) 421-5013
Email supportsupport@sanyotv.com
Describe your problem:
Top Air Conditioners Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
