Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Anonymous Posted on Jun 09, 2009
NEW BULB INSTALLED FOR PANASONIC PT-50LC13 TV STILL NO LIGHT
COOLING FAN RUNS OKAY CHECKED THERMAL FUSE GOOD NO OTHER NOISE BUT FAN CHECKED ALL OF THE FUSED AREAS ON BALAST BD. NOT SURE HOW TO CHECK SWITCHING SCRS OTHER THAN FOR SHORT. ANY THOUGHTS ? GREEN LIGHT POWER BLINKS ON FRONT OF SET THEN AFTER A MINUTE OR SO IT TURNS RED. THANKS!
Anonymous
Level 2:
  • Expert 197 Answers
  • Posted on Jun 09, 2009
Anonymous
Expert
Level 2:
Answers
197
Questions
0
Helped
91241
Points
366
Close lamp door set will not work with door open. if not that listen for arcing sound in back if  don't hear that bad ballest
2helpful
Tv has no picture or sound. replaced bulb no help greenlight blinks 79 times. red lights start blinking
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
We have a Panasonic PT-50LC13, the buld died and the unit would no longer light up. We replaced the bulb as noted and the unit still won't light. Do we need to reset something so the unit recognizes a new...
hi I just read that this tv needs a few minutes to warm up i am going to .try it. iam having same problem. i had a tv tech install a bulb and it worked .
but i had a dispute with the tech about the cost of the fix and he took out his bulb and all though i purchased a new housing with bulb in it so that i didn,t have to touch the bulb, when i put it in i got nothing but green to flashing red to yellow. so if my bulb is good and the tech didn't
do something malicous than something has to be reset so that the tv will work because not even the sound of the tv worked.
if you get the ansewr to this please email to [email protected]
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
I have a pt50lc13 panasonic that would not turn on. I bought the ballast repair kit and installed it and a new panasonic bulb. The tv now turns on, but only for about 5 seconds and then there is a click...
I'm not sure if this is the professional way:) -- but when my pansonic 1080i was acting up just like that - I placed a small fan at the back of the right side of the TV unit and faced it towards the TV air vents and voila the TV stays on and stays cooler. No more blinking lights. I don't think the cooling fan that draws the air out of the TV was working and the TV was overheating. Saved me some money in repairs and after a year it is still working well. A quick and cheap fix - but it worked. Jeanne
Panasonic TV pt-50lc13 bulb replacement
Take the bulb out, there should be a access panel in the front, power the set on,(be sure to have the lamp door closed) if you hear a rapid ticking noise from the set, the Ballast is trying to fire the lamp, this is a good indication that the set is functional but the lamp needs to be replaced. If not, the ballast is not getting the voltage needed to start the lamp.
15helpful
5answers
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
1helpful
2answers
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
3helpful
5answers
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
