I need to know how to time the whole machine. as i replaced more than the hook gear. Thank you so Much!
1st time feed dogs to raise and lower in time with the needle bar going up and down. Fit needle and slowly turn balance wheel towards you until needle is at lowest point, note where hook point is. Turn balance wheel towards you very slowly and stop when needle has risen about 3/16" from it lowest point. The hook should be immediately behind the needle and slightly above the eye.
SOURCE: Need an owner manuals for singer stylist 533 sewing amchine
None I found are free, but this one downloads for $8.
http://www.sewconsult.com/singer/singer_instruction_manuals.htm#500
Testimonial: "Excellent resource"
SOURCE: how do I set up my singer stylist 533 for flexi stitch?
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 533)
Click search
SOURCE: How do I replace the feed shaft gears on my singer
You can buy some instructions from Terry here. I got the ones for the 413 Stylist. They are acceptable and also show how to time the machine.
http://tandtrepair.com/StylistLine.html
