Refrigerators Logo
A
Anonymous Posted on Feb 09, 2014
Freezer not freezing - Dometic Refrigerators
Hi my defy f640 side by side have been giving me endless problems the red light comes on and the freezer does not freeze at all.
The red light that comes on and the freezer not freezing could indicate a few possible issues: Temperature setting: Check to make sure that the temperature setting in the freezer is set correctly. If the temperature is set too high, the freezer may not freeze properly. Thermostat: The thermostat may be malfunctioning, which can cause the freezer to stop freezing. You may need to have it replaced. Evaporator fan: If the evaporator fan is not working, it can cause the freezer to stop freezing. You can check to see if the fan is running by listening for it or feeling for air flow in the freezer. If it's not running, it may need to be replaced. Condenser coils: Dirty or clogged condenser coils can cause the freezer to stop freezing. You can clean the coils with a vacuum or brush. If you've tried all of these troubleshooting steps and the problem persists, it may be best to contact a professional technician to diagnose and repair the issue.
2answers
I have a Sharp Fridge-Freezer, model SJ-F78SP-BK. The Fridge compartment freezes. If left on overnight, everything will freeze as if it had been left in the freezer. Freezer is working fine.
please increase the temperature in the fridge portion of your fridge as it sounds like you've set that compartments temperature too low.
Thank you.
2answers
Why is my Defy F640 fast freeze light blinking orange
The blinking orange light on your Defy F640 freezer indicates a fault with the fast freeze function. There could be several reasons for this, including a malfunctioning temperature sensor or control board, a blocked or dirty air filter, or a problem with the refrigerant system.
To troubleshoot the issue, you can try the following:
  1. Check the air filter and clean or replace it if necessary.
  2. Make sure the freezer door is properly closed and sealed.
  3. Check the temperature sensor and control board for any signs of damage or malfunction.
  4. Verify that the refrigerant system is working correctly by checking for any leaks or issues with the compressor.
If you are unsure how to check these components or suspect a more serious issue, it may be best to contact a professional technician to diagnose and repair the problem.
My kenmore upright freezer is running but not freezing is there a reset button
**Freezing gas may have leaked out at some point. Compressor works but freezer not freezing.
**Thermostat setting not suitable for freezing to occur; check and adjust
**Check whether evaporator at the back of your freezer is hot/slightly warm to touch. If it's not; call your freezer service/repair man asap
My freezer will not freeze or cool. I checked the compressor and us cool to the tough but the copper is very hot??? Help please
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Also, using a freezer to cool hot items or opening the freezer frequently will affect the... the freezer is running but not freezing is improperly packing the contents.
Fix a freezer not freezing but still cold - YouTube
? 1:34
www.youtube.com/watch?v=hCUewYVyiFQ
Aug 19, 2013 - Uploaded by Dave Here My freezer wasn't doing a good job freezing but there was ice on the back ... If not, approximately how often will I need to repeat the process?
2answers
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Refrig not cooling but freezer is
The freezer door not closing properly would caused the freezer to freeze up
6helpful
3answers
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
