Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater Logo
c
clint novak Posted on Feb 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The heater temp lights up but the heater never turns on
Elisa Jed
Level 2:
Champion:
Habit-Forming:
  • Expert 210 Answers
  • Posted on May 08, 2014
Elisa Jed
Expert
Level 2:
Champion:
Habit-Forming:
Answers
210
Questions
0
Helped
42882
Points
203
There is probably a problem with the wiring. Either there is a short or a wire has become disconnected. You can probably open the heater up (carefully) and see what is wrong. If you aren't feeling comfortable with that, bring it in to a repair shop.
Elisa Jed ' http://www.orlandoac.com/
Why doesn't the fan on our comfort zone heater turn on when I turn on the power?
You need too hit the temp button increase temp then hit enter or set
How do set the temp on a 15 gallon tank
leave the heater unplugged in the aquarium in for several hours.Then plug it in briefly and see if the neon bulb lights up (sort of an orange color). If it is on, turn the temp set knob counter clockwise until it goes out. Then turn the knob clockwise slowly until the light comes on again. Now your heater is set for approximately the current temp of the aquarium water. Now adjust the knob in very small increments, waiting hours between adjustments until the water is at the temp you want.
Turn off service light
What exactly is the heater doing. You turn on the filter pump, flip the switch on the heater, does it turn on? Does the board light up?
I have a hydroquip hot tub heater system. Everything works great but no heat. Heater indicator light does not come on. Just replaced the pressure switch, & still no heat. The heat light on topside con
Bad heating element. Shut the power to the breaker off, disconnect the wires off of the heating element and then check for (ohms) continuity across the two element leads. If it show OL on the meter then you here is an open in the element and it will need to be replaced. Good luck.
Oct 04, 2017 • Pool & Spa
7helpful
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
2helpful
2answers
Hot water heater states lockout
lucky for you I jst did one of these the other day same problem,, check the wires on the ignitor, some of them are thinly coated and causes them to short out, wrap electrci tape around them individuly turn off the unit , wait 30 sec, turn it back on at it;s lowest tem hold both temp buttons at the same time till lights come on the after it lights set the temp
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
