May be you should make a diagnostictool,give for your reference: OBD diagnostic tool one stop supplier,you can do it by yourself if you want to do it by yourself.
Providing OBD auto Diagnostic tools for both professional and DIY garage repairing work at reasonable price and worldwide shipping including auto diagnostic tool auto key...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.
May be you should try to restart your phone and reinstalling the firmware may also solve this if these options not work then you have to change your phones display screen
try opening it up and pinching the two prongs around the patch cord to tighten it up. My bass was cutting out for a while and giving out no sound till i did that
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks [email protected]
