Hello, I have 2002 hondacbr600f4i, the PGM-FI UNIT damaged so that I bought a new one ( 38770-MBW-A12) my bike now with my technical garage he has checked the WIRE HARNESS that is good no problem on it. he tried to transfer the code from key to PGM-FI several time " from computer " I don't know how. at last he connect the PGM unit and turned key on the FI lamp work " ok" put the amplizer lamp " code lamp " don't flashed or work what can we do to resolve this problem . what the best method to transfer key code to PGM unit note: we don't have honda service center here. thanks
SOURCE: CDI Unit for Honda Baja (2003) - Black Color bike.
Get on the web and GOOGLE " motorcycle salvage honda ".
If you can't find the CDI unit there you won't find it.
Please rate this solution. Thanks!
SOURCE: my keeway wont start
Check the fuses. Is the kill switch on or shorting out? Disconnect it and then check for spark. Sidestand/centerstand should be up, Got a good battery?
I am unfamiliar with your Keeway and just trying to help. Don't give me a bad rating if I miss the mark on this one. Thanks.
SOURCE: 92 honda cb 750, oil light will not go out, bike won't start
Look around the engine oil drain plug and fill area and see if there is an electric sending unit( small plug with a prong for a wire) that is screwed into the engine if so check to see if its unplugged / could be a low oil cut off switch that kills all power to the ignition if the oil is to low ( or the wire is unplugged)
SOURCE: 19-95 KLF300 ATV Kawasaki 4x4 no spark put new ignitor unit on.
i ******* hate my kawasaki kdx 125 1992 there is no spark and i dont no wot it needs ive bought a cdi for it an it wernt that and i bought a new coil and it wernt that either could anyone help me please
SOURCE: will a two cdi box system work on a wire harness
No it will not work.
Testimonial: "Quick answer. Wish i knew why they won't work though, same year bikes and make other than mine is a vt500c the other is a vt500 both 1985."
