Samsung c160 dead problem solution image
Get a new one... or you could tell people what the actual problem is that might help
Here is a trick if you absolutely nee to recover your info. 1. Find another drive-the exact Model # 2. mount the drive in an external case make sure the drives circuit board is accessable. 3.plug the new drive into usb port make sure it has been recognized 4. remover the circuitboard and plug from the old drive 5.with the usb plug still pluged in,carefully unscrew & remove the circuit board from the new drive and place in on the old drive. go to my computer and click on you drive and be prepaired to back up your files. once you unplug the old drive you will have to repeat the process to access the old info again
