Mobile Rack SNT-125 SATA Plastic for serial ATA HDD (without extension front ports) Drive Case Logo
Posted on Jun 04, 2009
L use two hard disk in my computer by raid , sata type ,my hard disks use snt-125 sata plastic ,in the normal opration must found two hard disk in the cmos,but now i found one hard disk ,so i opend the cover of snt and swap between two hard disk, i found one case of snt 125 when i put hard disk in it the no difine this hd,there is switch in the small circuit in back of snt-125s but idont know whats it function,the cicuit snt-125 sata v2.23 i would like any information to solve this proplem
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
171
Points
This switch is only to able or disable the led hard disk indicator in front of SNT-125SATA Mobile Rack
Regards,
Euclides, Panam?
How to change sata to ata in bios
If you want to install Windows XP or configure a RAID array, you may need to change the SATA type in BIOS. here I will introduce some method of SATA settings in BIOS. SATA HDD(hard disk) has been more porpular because of the hight transferring speed and simple installation. If you want to Install a Windows XP in SATA hard disk. we offen need a floppy disk to save the additional driver of SATA/RAID. but the floppy isn't too easy to find. So we can do another method, modify the SATA type to compatible IDE or ATA mode, etc.
Notes: If your computer has installed some operating systems. Changing SATA types may corrupt your systems or need to be repaired again. But when can I change the SATA type?
1. You are prepairing install a new operating systems, for commonly Windows XP. If Windows 7/Vista will be installed. you need nothing changed in BIOS unless the setting has been modified.
2. Or you want to install a RAID.
I will introduce how to install Windows XP at SATA HDD(hard disk) in the coming chapters, here we need to know how to change the SATA type in BIOS. At first we need to access BIOS, Here is my desktop BIOS, we can find the BIOS is from AWARD software.
201003290718324672.jpgIn my BIOS, the harddisk settings are in the line of integrated peripherals, different BIOS or different OEM menufactures may have different promise. you can try the Advanced BIOS features setting or Integrated peripherals, or system configuration, etc.
Locale to Integrated Peripherals and press enter, you may find the SATA configuration.
201004010308121905.jpgthe above screenshot is the SATA configuration position. There are two items about SATA controller, Onchip SATA controller and Onchip SATA Type, Notes: There may be one or more configurations about SATA, we only need to change the SATA Type. you should not close the SATA controller if you don't know what's will be happened.
Navagete to the Onchip SATA Type and press ENTER, we can find these selections: Native IDE, AHCI, RAID. If you want to install Windows XP, you may need to change to Native IDE(some called ATA) mode, when you finished installation, you can refresh your SATA drivers in Windows XP and change the SATA type to AHCI mode in BIOS again.
If you want to configure a raid array. set to RAID similarity. When finished settings, you should press enter to accept it, and save to CMOS before restart your computer. In my BIOS, I need to exit to the BIOS main menu at first and save it.
when the new status has been saved, you can press CTRL+ALT+DEL to restart your computer, some OEM PCs may need to click the EXIT or Save to CMOS and Exit, the computer will be restart automatically.
Another example screenshot is my DELL notebook BIOS. DELL BIOS is not the same as the desktop BIOS, we can find the SATA operation behind the System Configuration. there are only three selections (Disabled, ATA, AHCI). If you want to install Windows XP, here need to be changed as ATA mode.
201004010308185104.jpg Notes: If you want to install operating systems, you may need to change the boot orderto boot from your CD/DVD drive.
tip
Windows XP setup disk says disk not found.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
on Apr 15, 2009 • HP G60-120US Laptop
I have a toshiba labtop with 2 hard disks working as raid. but I have formated my computer and now I lost the raid technology , so how can I restore it. I have the recovery CD and it should do it...
u will need a os setup disc which contains sata/raid support. u can make this setup disk. find out which sata/raid text mode drivers needed (i can't tell u which txt mode driver is needed as i don't know the model no. of the laptop)
find textmode driver needed for your model no. using google.
copy os setup disc(windows) on to the hard drive. use nlite to integrate textmode sata/raid driver. burn a bootable disc.
Recovery disc wont work as u have already formatted the drive.
1helpful
Hard disk not found error during Clean XP home Install
How to install windows xp sp2 on compaq v3239tu
1helpful
I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
Problem on loadind windows xp on hp pavilion dv2000 laptop
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
1helpful
Motherboard does not have a SATA configuration on bios setup
use third party raid driver.use floppy drive for installation third party raid driver.
Top Mobile Rack Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mobile Rack Computer and Internet Expert? Answer questions, earn points and help others
