My laptop is vista compatible i want to install windows xp service pack2 but at the time of installation it show the message hard disk did not found . how to install windows xp sp2 in my laptop v3239tu?
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see: Resolving "Setup did not find any hard disk drives" during Windows .
DID YOU RESOLVE THE HD PROBLEM
