My Toshiba SK9 laptop's USB ports do not let me connect any peripheral (eg wired mouse) but it does transmit power to the mouse. What could be the problem, and how can I fix it? Vasant
Since you know you have power and I am assuming none of the USB connectors pins are broken or shorted then what is happening is that another driver is stepping on the USB driver. Check Device Manager for erros. If none then at the run prompt type SFC/scannow. Have your original operating system disk ready because if it finds problems it will need to install the corrections. The original disk IS NOT the recovery disk (this won't work). If this does not correct the problem the operating system needs to be repaired. Email me for further info.
