Assuming it finally goes off. The camera is busy saving the image to memory. You may try faster memory cards to shorten the wait time. You may also need to save all your images to your computer then re-format the card in the camera.
Possible reason why do you get an error " Please wait for camera to finish recording " is accidentally you turn off the camera, or new mode was selected while images are being recorded to memory card. This message automatically clears off the camera display when camera finishes writing data to card.
I suggest that do not turn off the camera,removed the memory card, or removed or disconnectthe power source while the hour glass icon is displayedor while the green autofocus lamp is blinking.
Condensation can form inside the camera if you take the camera from one environment to another where there is an extremetemperature change.
Simply wait until the condensation disappears. The warning is to protect tape and camera.
It probably means that a moisture sensor has tripped inside the recording mechanism.
Did you take the camera from a cold (i.e air-conditioned) place into a warm place?
Generally waiting 'til the camera has warmed up and whatever moisture inside has gone away will let you use the camera again.
Type *#197328640# in the Idle mode, then you can reach the test mode.
b. Select [6] Video
c. Select [3] Camera Firmware update
[Please Wait] will be displayed.
Wait a few minutes then [Please Wait] will be changed to [SUCCESS]
try this go into device manager, remove ALL the USB, uninstall all the drivers, reboot PC, install the software that came with your camera, reboot, at next desktop, wait say a few mins, and NOW plug in your camera, you should hear a dong dong, it will then either install or ask for drivers, point it to the software that you used to install, wait until finished and with it still attached, reboot, wait until desktop appears next time, and wait a little bit, now your camera should work.
This is often referred to as DEW and is a sensor inside the camera that detects moisture. You can hasten the removal most times by warming the camera with a hairdryer on medium setting and not too close to the plastic case. When you store the camera store it with a few of those little bags of silicone crystals that come in many packages that we just throw away.
