STUCK TAPE I HAVE TRIED THIS ON SEVERAL MACHINES. I INSERT THE TAPE AND IT GETS HUNG UP, DOSN'T MOVE AND REFUSES TO EJECT. AFTER REPEDED HITS ON THE EJECT BUTTON THE TAPE COMES OUT. IT APEARS THAT THE TAPE IS STUCK TOGETHER. CAN YOU HELP PLEASE?
Make sure the tape hasn't wound around the drum. If it has then press the eject button several times. Check the loader motor to see if the belt is slipping or has fallen off.
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Then I unscrewed the bottom panel of the radio. Unscrew the brass screws holding in the cassette player portion of the radio. Now flip the cassette player over to see your tape, etc. When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound. I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
When a tape won't eject, the problem can be caused by several things.
The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced.
Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor.
Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft.
You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge.
While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved.
Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism.
Please let me know if I can be of further assistance
- Jim
The problem may very well be a slipping spool idler that does not tension the tape properly when trying to eject. Try cleaning the rubber friction surfaces or replacing the part....accordianman
you posted 2 different problems here... to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
