Question about LG LSC26905TT Side by Side Refrigerator
Wires hanging in ice maker area
We just purchased a used LSC26905TT refrigerator. When cleaning it out, we took the cover off the ice maker and there is a small white sensor with 2 white wires hanging on the right side behind the ice tray. I am wondering if anyone has a schematic on can tell me where the sensor belongs.
Thanks
    Problem Solver:
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
Posted on May 30, 2009
How do you replace the ice cube tray in an LG Lsc26905tt ice maker
  1. LG LSC26905TT - YouTube
    ? 0:08
    www.youtube.com/watch?v=7dm-D7PtOOc
    May 22, 2011 - Uploaded by theholytoast
    Icemaker Ice-maker malfunction. ... LG LSC26905TT ... FridgeIce Level Arm Replacement - LG Refrigerator Repair (Part #4510JA3003D) ...
Jul 23, 2015 | LG Refrigerators
My ice machine not making ice
Is there ice in the ice maker? If there is frozen ice in the ice maker, ice maker is probably faultily.
Ice Maker Repair
Dec 05, 2012 | LG LSC26905TT Side by Side Refrigerator
My ice maker not making enough ice . I have already check the water. thank you
When an icemaker slows production, the problem is not the icemaker at all but the temps in the freezer warming up because of an airflow problem either in the freezer compartment evaporator coils or underneath the unit that being the condenser coils. (Fan not working or lint blockage)
Airflow problems in the freezer compartment are caused by the fan or the automatic defrost system not functioning properly so yu end up with an ice block / lots of frost in the freezer compartment on the back wall of the compartment.
Check for ice or large amounts of frost in the freezer compartment. If you note ice / excessive frost, unplug the unit, empty the freezer compartment and do a manual defrost by directing an external fan into the compartment for just over 2 hours. This will ensure the evaporator coils and the freezer compartment drain have thawed. While the manual defrost is in progress remove the rear fiberboard cover from the compressor access and check / clean the condensor coils and fan area.
After 2 hours clean up the excess water.. reassemble the rear cover and return the unit to NORMAL service. It should start making lots of ice in 4 to 6 hours. Here is the kicker... if there is an auomatic defrosting problem your icemaker will after 2 - 3 days again slow ice producion and ice will build up in the evaporator area. You will have to keep repeating the manual defrosting process every 3 to 4 days until the automatic defrost system is repaired.
There are 3 main components of the Automatic defrost system:
1. Defrost control
2. Defrost heater
3. Defrost thermostat or depending on type thermistor
Most of the time the problem is either the defrost control or the heater that fails and the unit stops defrosting.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LSC26905TT/3204/0165000
Thanks for choosing FixYa,
Kelly
Jun 23, 2011 | LG LSC26905TT Side by Side Refrigerator
I need to know how to fix the water valve and the ice maker line om my LG Refrigerator Model # LSC26905tt
The plastic water hose hanging in the back outside of my LG refrigerator that connects to the main water pipe has many little, tiny holes. I tried to change the hose but I couldn't find a way to take the old hose out to switch it with a new one. Will you please give me some directions how to do it. Thanks.
Jun 04, 2011 | LG LSC26905TT Side by Side Refrigerator
Ice maker keeps filling up, how do i turn off when we don't need ice or we are away from home.
There should be a wire on the side the you just lift up firmly to stop the ice production...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 13, 2010 | LG LSC26905TT Side by Side Refrigerator
Fan is making a loud noise by the ice maker. Sounds like it is rubing against something. It turns off when you open either door.
the fans normally stop when you open door fan probably has ice or frost in cover area remove food from area and check cover make sure not cracked and pushing in on fan also check and see that fan doesnt have plastic or foil stuck in it if ice dont have to defrost whole system clear food away and use a hair dryer on high directed on fan housing after a few min 8-10 check fan to see if ice or frost is gone
Sep 28, 2009 | LG LSC26905TT Side by Side Refrigerator
Lg lsc26905tt ice maker makes ice, but wont turn dispenser
you can look to see if something from the freezer dropped into the chute? it may have blocked the exit. Is this all new ice or has it been a while since you used it? Maybe the auger in the bin is stuck?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker
pammytrent:
The icemaker only harvests / drops once the icemaker get to a temperature of Approx 15 Degrees.
Most manufactures Icemakers make approx 70 icecubes in a 24 period .
This can depend upon ambeint temp, use of product [opening closing of doors.
You will need to make sure the your condenser coil under the unit is clean.
Before cleaning disconnect power to unit first.
Air flow curculation in freezer can effect production also . too much food can restricting air flow, to little in freezer can effect ice production too .
hoping this helps
woodychoppers
Jul 07, 2008 | LG LSC26905TT Side by Side Refrigerator
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
424 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
