It sounds that the main board if faulty. If you wish to get more details, check this
site. Pull up older posts there. Check the site with patience, as it has over
2350 posts now. All are related to
electronic equipment repair help.
Search the site by 'Timeslide' option.
It will make search easy.
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Hi, Its symptom of weak lamp that reaches to end of its working hours life span. If lamp has not been replaced in last 2-3 years then replace it to fix tv problem. Lamp replacement procedure is easy and written in user manual. Please buy Sony original lamp for good picture in tv. Thanks.
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety. Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy. Thanks.
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
