Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready Television
Problems with Sony Grand WEGA KF50XBR800 50 in. Rear Projection...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Sony Grand WEGA KF50XBR800 50 in. Rear...
Troubleshooting and Support
Solved Problems for Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready Television RSS Feed
View More Results for Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready Television
Questions and Unsolved Support Problems
Unsolved Problems for Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready Television RSS Feed
Answer
The t.v stays on for a few minutes and then it turns off.During that time the stand by signal keeps... (More)
Answer
Stand by light is on when TV switches itself off...and on and off (1 minute each time) until I... (More)
Answer
Sony KF50XBR800. Have heard similar problems. Set goes on, works fine and then shuts off and... (More)
Answer
I have a Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready. It has been turning off. A... (More)
Answer
My set will play for a minute or two then go out. The standby light will flash in intervals of five.... (More)
Find a Manual
Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Sony Grand WEGA KF50XBR800 50 in. Rear...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready...
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Warranty Information for Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready Television
Specifications for Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV-Ready Television
Key Features
Screen Size
50 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Digital TV Standard
HDTV-Ready
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Component x 2 · S-Video x 2 · Composite x 3 · DVI x 1 · RF x 2 · Audio (RCA) x 6
Rear Output Connectors
Composite x 1 · RF x 1 · Audio (RCA) x 2
Memory Card Slot
Memory Stick
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 15 Watt
Dimensions
Depth
16.38 in.
Height
43.5 in.
Width
54.25 in.
Weight
111 lb.
Warranty
Overall Warranty
1 Year
Tube Warranty
2 Years
Sony Contact Information
Main support number800-488-7669
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
