20 Most Recent Sony Grand WEGA KF-50WE620 Television Questions & Answers
take to a repair shop but be prepared to buy a new set. some parts may be no longer available .
Sony Grand WEGA... | Answered on Jul 07, 2015
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Sony Grand WEGA... | Answered on Mar 27, 2015
look in menu to see speakers did not for some reason get turned to off and also see if a DVD connected to a rear input has sound or not.
Sony Grand WEGA... | Answered on Dec 19, 2012
If no aspect button on original remote you may be out of luck.
If using the set with a box might want to unplug box and set to see if that helps--some boxes also have a aspect setting accessed with the box remote.
I would first see if same issue when going directly to any rear audio and video input, might narrow down where the problem is or is not.
Sony Grand WEGA... | Answered on Dec 17, 2012
The screen has failed and will need to be replaced.
Sony Grand WEGA... | Answered on Oct 12, 2012
From your discription it sound lie you have some burnt out pixels which are not fixable
Sony Grand WEGA... | Answered on Oct 11, 2012
This model does not have a lamp timer.
Sony Grand WEGA... | Answered on Jun 22, 2012
follow your manual or take it to Sony office near you if any
Sony Grand WEGA... | Answered on Sep 26, 2011
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Sony Grand WEGA... | Answered on Jul 08, 2011
Hello.
if you want to reset lamp timer on sony grand wega 50WE620...press menu on remote control then go to the setting you will find the setup button then press setup you will see the lamp replacement-start----yes and menu...
Thanks for using fixya
Caseytech
Sony Grand WEGA... | Answered on Jun 29, 2011
its a failing optic block and needs to be replaced they are however very expensive to but and quite alot to install too im sorry to hear of your misfortunate mishap good luck ok
Sony Grand WEGA... | Answered on Jun 03, 2011
A 6 blink error code on this model is letting you know that your G1 board is not putting out your +17 volt supply. You can inspect that circuit if you are experianced, or just swap out the board.
Sony Grand WEGA... | Answered on Apr 01, 2011
Your Optics block has gone bad. It's been a problem with Sony for many models recently. The cost of the part can run between $800-900. Total job may be around $1200 if the part is still available. My distributor shows it on back order. I can't say it's a good investment.
Bill W
integrityhomeworx.com
Sony Grand WEGA... | Answered on Mar 23, 2011
take the back off.
Sony Grand WEGA... | Answered on Feb 26, 2011
Yes, when you get the bulb, it comes with instructions. Takes 10 min.
Sony Grand WEGA... | Answered on Jan 14, 2011
Televison & Video Logo
101 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
connect sony wega kf 50we620 xbox360
  • Televison & Video
