Kenmore Series 80 HEAVY DUTY, SUPER CAPACITY PLUS, 110.C76822695. runs for ~~10 minutes then quits. ALOT of noise down below (maybe the motor), noise increases then machine quits. Everything else works. Don't know how to remove front to look at inside. Got back off and vacuumed out. Anywhere I can get a FREE manual to look at and read. Thanks, Dave
Https://www.searspartsdirect.com/drmotor in a stallyer-repair/repair-guides.html
Drum rollers are common noise makers and if let go too long could possibly put the motor in a stall.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: turn off buzzer
Assuming you mean the end of cycle alert. The only way to do this is to follow the wiring diagram and install a switch to cut it off.
SOURCE: Dryer only blows cool air
my dryers works just blows cold air,can you help?
Thanks,
Xavier
[email protected]
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
SOURCE: heavy duty super capacity plus
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
SOURCE: 80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
