SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
SOURCE: Motorola Razr Security Code
if you're looking to view the security code, you need to dial six 0's not four. If you want to get into the programming menu dial #073887* fastly and enter the six zeros.
SOURCE: radio problem, keeps beeping and saying code.
On the controls on the steering wheel hold the vol + & - for a couple of seconds and this should bring up the 0000 on screen and then its a case of spinning the wheel control on the side and holding + & - to set it.
SOURCE: lg Scoop unlock code
did you dial ##3282# or ##3282##? dial the second one i said. then if it ask for
