Question about Sennheiser Audio Players & Recorders
On/off light on sennheiser rs 170 base keeps blinking?
Charging light not lit, and power light (green) keeps blinking. should it be a steady "on" green light?
  • 624 Answers
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
SOURCE: Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Posted on Jun 19, 2008
  • 11 Answers
SOURCE: KDF-E60A20 Going on and off by itself..no blinking lights
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
SOURCE: green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Posted on Jan 17, 2009
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
Blue light is not blinking or on at all when i set phones on charging dock.
ck that batteries are installed correctly and contacts are clean. Put the old batteries in, if it is not trying to charge them, sounds like the charger is bad.
Apr 24, 2014 | Sennheiser RS 140 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
THE HEADPHONES ARE CHARGED BUT WONT WORK. THERE IS A CONTIOUSE GREEN LIGHT WHICH IS ON. ON THE HEADPHONES.
Wireless? Are they connecting with the base? Try unplugging the base to reconnect. What are they connecting to? TV? computer? What?
Nov 10, 2012 | Sennheiser RS 120 Consumer Headphones
I have a huge problem with these headphones (the Sennheiser HDR 120)... and my wife bought two of them... They have great sound on the computer, but once the green light turns off on the base? There...
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
Aug 12, 2011 | Sennheiser RS 120 Consumer Headphones
Toshiba satellite A100 dead. orange steady battery light with mains connected and power button lights shift key and 2 function lights - that's it.
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
Sep 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its variable..you will have to increase the output or volume to activate the base..
Jan 26, 2009 | Sennheiser RS 120 Consumer Headphones
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
Jan 08, 2009 | Sennheiser RS 120 Consumer Headphones
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
143 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
