Sennheiser RS 120 Consumer Headphones Logo
ANDREW LEWIECKI Posted on Nov 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
THE HEADPHONES ARE CHARGED BUT WONT WORK. THERE IS A CONTIOUSE GREEN LIGHT WHICH IS ON. ON THE HEADPHONES.
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Nov 10, 2012
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1015304
Points
21773
Wireless? Are they connecting with the base? Try unplugging the base to reconnect. What are they connecting to? TV? computer? What?
The green charging light is not coming on when the headset is placed on the charging station
Wait to see if it gets a charge on the port. If the headphones don't work, call customer service for troubleshooting relief.
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Headphones Panasonic
if these are older headphones it's likely that the batteries have gone bad or are defective, if this is a new unit, (aside from returning it for working one) it could still be the batteries, but the other likely issue is the charging unit is defective. you could test with a volt meter to see if it's getting juice. you could also have a short in the headphones somewhere.
Wont turn on
2 days old and defective return for refund or replacement
Green light keeps flashing and head wont charge
Had this problem too
just remove the rubber cap where the charger bit is and replace the 2 RECHARGEABLE batteries. If the light is flashing just turn the power off on the headphones. :)
7helpful
Bose QC 2 Noise Cancelling Headphones the red light is on. Should there be a green light if they are working?
No green light for QC2, just red. If it's constant the battery is charged, powering the noise cancellation, and, if connected to an audio device, conducting sound. If the red light is blinking, the battery is losing its charge.
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Hear sound out of computer rather then earphone. Has worked great up until now. Blue light will not stay on. When charging light is red.
when the red light is on while charging it means it is at less than 25% charge let it charge until the light is green
then tryy connecting it to the computer
3helpful
2answers
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
2answers
Headphones wont turn on
battery is toast get a new one anything electronic if u do not upkeep the charging it will die qwik
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
