My dvd will not eject. Disc plays fine. I push the eject button and the screen says 'Open' for a few seconds, then "load' appears.
SOURCE: DVD won't eject
Same problem - same solution. I have tried to verify if there is too much movement in the tray (vertical) but it is a random issue with mine..... except now I can't get system to recognize I want to load DVD instead of tape! See separate thread.
SOURCE: Disc Error, and DVD tray ejecting on it's own....
If it is new, best advice is to take it the Comapny Service Centre, as you are having Warranty.
SOURCE: DVD player freezes
If it's a very cheap unit, it's possibly because the machine can't process the information quickly or efficiently enough, thusly causing the picture to freeze up while the processing catches up with it. Friend has a $30 unit, which happens to constantly.
SOURCE: DVD Eject tray stuck
Your problem is more than likely mechanical. There is a belt that makes connection between the motor and the loading mechanism. Take the unit apart. Remove the belt it is probably in the front. Clean the belt and pullies with denatured alcohol. reassemble. The best solution is to replace the belt but this may get you working till you get one. Belt sources http://www.mcmelectronics.com/
please visit my eBay webpage
http://members.ebay.com/ws/eBayISAPI.dll?ViewUserPage&userid=wilcox1976
SOURCE: DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
