Maytag MGR5751AD Gas Kitchen Range Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Maytag Gas Range, Precision Touch Control 500. The oven quit heating up. When we turn it on by hitting bake and touch the temp up to 400 degrees it always stays at 100 degrees and never heats up. Everything else is working fine, the top burners work fine, the broiler works fine but still the oven does not heat up. Anyone have any suggestions?
Anonymous
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on May 18, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
85
Questions
Helped
32814
Points
231
Likely your oven igniter is bad. Part number 74007498
1 Related Answer
Anonymous
  • 67 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
you need to replace the oven ignitor
Oven will not turn on after self cleaning has finished
If electric turn the oven to bake and look at the bottom element. If if does not turn red hot, it may be defective.
If gas, turn to bake and watch the igniter to see if it get red hot. If not, it may be defective.
May 22, 2014 • Ovens
Maytag precision touch control 500
Either both bake and broil elements are burnt out (highly unlikely) or your control / clock may be bad. Also check to be sure you have 220v going to unit.
Oct 02, 2017 • Ovens
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 • Cooktops
4helpful
2answers
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 • Ovens
Gas Oven Won't Light
make sure the wire is connected to the ignition(where it sparks)if it is gently clean the sparking surface with a piece of fine sandpaper.Hope this helps,if it still does'nt work you may need to replace this part but it should'nt be expensive and you can do it yourself(usually one screw) ps sorry for the late reply.
Overn will not work properly
sounds like you have a bad oven ignitor, very common problem with alkl gas ranges, easily repaired by you a few screws and a wire harness part number 12400035
Apr 05, 2008 • Ovens
2helpful
2answers
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
5helpful
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
