SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
SOURCE: SHX46A02UC dishwasher will not complete cycle.
Test the door switch and its wiring. The dishwasher is supposed to stop when door is open.
About drain pump, check the pressure switch and eventually replace it(pressure is water level, this is not the float, that is usually overfill-if there is no pressure switch, check float). That is the device that detects if drain is over, stopping the drain pump.
