Panasonic SA-HE200 Receiver Logo
A
Anonymous Posted on Dec 23, 2013
Overload message - Panasonic SA-HE200 Receiver
Where is the reset button on Elna6004 6004, overload message keeps appearing
The message means that the motor is drawing too much current. Could be a mechanical bind or the motor itself is worn out.
Hope that helps.
1helpful
Lg wd-3245rhd LE error message
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Got overload message; batteries were a year old so replaced them today. Just got overload message again after 20 minutes of use.
Overload has nothing to do with the batteries being old or new...it has to do with with how much watts you are sending through the unit...if the overload protection fault is on, it is because it is sensing that if the power were to go out the UPS would not hold up the load at all. I do not recommend to load the ups more than half of the load. visit a batteriesplus store near you and they can help you with this in more detail. www.batteriesplus.com
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
"Overload"
Check your wires for cross polarity
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
