Low Heat -
This problem is not usually associated with the heater element but more
often a result of water flow issues. Specifically blockages such as
dirty filters, partially closed valves etc...
But... excessive scale/mineral build up on the element is on uncommon and can result in reduced heating. The fix is easy, use
chemical treatments to reduce scale build up.
No Heat
No heat or water is only heating to 60F- 80F?
If you are getting a low reading this is because the water is only being
heated by the friction caused by running through the plumbing system
and pump.
Assuming there has not been a dry fire (visual signs of burn/overheat
marks/ damage to the heater tube) and your temperature sensor and hi
limit are in working order.
A bad element. Like a light bulb,
spa heater elements will burn out over time & there are many factors which affect their longevity.
