20 Most Recent Masterbuilt 20070411 30" Electric Smoker with Window Questions & Answers
I have the same model and drew this schematic after taking it apart to fix another problem. An EAA1 means that the control display unit is getting a bizarre reading from the temperature sensor on the box. Could be a connector problem or a faulty temp sensor. The temperature sensor has a long path through the relay power supply board in the bottom then up to the control display unit. Unfortunately the only place you can easily check is the 5 pin connector directly under the control display unit. Try reseating this connector. The box can be opened up to check everything else but it's a real bear.
Masterbuilt... | Answered on Nov 22, 2018
EAA2 means connection to the meat probe is lost. Either a broken, burnt wire or the probe itself. Check the probe wire carefully to spot a break.
Masterbuilt... | Answered on Jul 20, 2016
I just fixed mine. Here's what it basically looks like
a smoker typically does not run as hot as a grill does you know
Masterbuilt... | Answered on May 30, 2018
Google (Masterbuilt)(20074517)(manual) without parens.
Masterbuilt... | Answered on May 27, 2018
Masterbuilt 20070411 30" Electric Smoker with Window Logo
Popular Tags
3 questions posted
Top Masterbuilt Grilling Experts
Ted-L
Level 1 Expert
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
View Most Popular
  • Masterbuilt Grilling
Most Popular Question
am getting eaa1 error after 5 minutes
  • Grilling
