Master password is unknown, need to reset to access footage
The DYK4500 is a DVR system and is not a Windows or traditional computer. It does not have an optical drive. You may first want to just hit enter and see if the password is not set. Try any other methods first, and if all else fails, you can attempt a reset by removing the BIOS battery and jumping the contacts for 30 seconds. This method sometimes has issues that are tough to recover from if you don't have the remote. You'll often get to a first screen that shows: HDD0 Detected, HDD1 No Device. Haven't figured out how to bypass this window without the remote. With the remote, you should be able to press '0' twice.
SOURCE: password unknown and no disk to restore
Ok in order to reset the password you are going to have to download and burn a ultimate boot cd. The iso can be found here: http://pharry.eu/data/ubcd411.iso.php. The official site is here: http://www.ultimatebootcd.com.
I hope this helps.
This has been tested on a windows xp machine. Though it should.
SOURCE: remove password on f2 bios setup utility access,
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
