What operating system are you using? Is you camera connected via USB? Have you tried using another USB port? Did you make sure to install the software before plugging in your camera?
Generally if you are running Windows 98, you will need to reboot after installing the software to even have a chance of the camera being recognized correctly.
If you are running Windows 2000, XP or
Vista, the camera should be recognized and a driver installed or searched for from the CD software you installed before plugging in the camera.
Sometimes if you plug in the camera first without installing the software, the PC finds a new device with no driver. You can see this by going to Control Panel -> System ->
Hardware -> Device Manager and you should see and exclamation on a device in the list. You need to remove this item and reboot your PC.
Now install the software first and when the install is done, then plug in your camera. Generally this works out pretty well.
My computer does not recognize the driver that came with it.
I have tried every way,even downloading drivers but no such luck!
when i connect my camera to my computer using USB, i can't open the camera to view the photos.
I have a similar problem. I actually got windows to recognize the camera by reinstalling the drivers, but when the windows wizard connects to download a pic from the camera, the image becomes corrupted. I should point out that I took the camera to work and had no problem using it on those computers (which are not hooked up to the internet nor has windows been updated on them). Is this possibly a windows SP2 issue?
I must have a lousy usb port...i switched to a port in the back of my rig that i never use and it worked like a charm.
I NEED THE USB DRIVER FR=OR THIS CAMERA
i plug my camera into my computer and it says it doesnt recoginze the devise
Exact same. I uninstall and reinstall it, it doesn't work.
Exact same. I even tried reinstalling it. But I plug it in and it says something like it has malfunctioned. I check in the device manager and it says "No drivers are installed for this device"
