SOURCE: Why did my HP Pavilion ze2000 screen go black?
john79:
I know that you had a chat about this matter, and I hope that your issue was solved. However, I had made a note of it when I saw the chat go through. I was unable to help at that time, but remembered having seen something of this nature and wanted to follow through on it.
Although the ze2000 is not listed, other 2000 models are listed in the following link as defective - and recognized as such by HP - with this very specific defect. (Please see http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c01087194.)
Again, if your issue has already been solved, congratulations. Otherwise, I hope that the information provided here will be of use to you, either in fixing the equipment problem yourself (perhaps with a BIOS update) or by convincing HP to do something about it. At least you would be armed with good solid documentation of their recognized issue!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
SOURCE: laptop boots then shuts automatically off
If you haven't tried it yet, pull the battery out and try booting from the adaptor only.
If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge.
Under normal conditions, they should measure a couple of percent higher than their rating.
You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
SOURCE: HP Pavilion Dv6700 black screen after booting up
Go to the following HP website to view the problem and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=us&product=3636595&rule=21826
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
SOURCE: My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 ....
Sounds like something to do with a power saving feature either from HP itself or from Windows. It could also be that for some reason your computer is overheating, which it than shuts itself off to protect the processor. I would try playing with your power saving features, and cleaning out the fans.
SOURCE: HP ZD7000 laptop screen won't work.
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
49
