My frigidaire affinity front load washer will not start when pressing the start button. No errors or anything just confirms that the start button was pushed with a beep, but nothing else happens.
Check voltage incoming to unit if ok check past switch where the voltage dies indicates what part is bad
Electrical power cord may not be plugged in or connection may be loose. Make sure plug fits tightly in wall outlet.
House fuse blown, circuit breaker tripped, or power outage has occurred. Reset circuit breaker or replace fuse. Do not increase fuse capacity. If problem is a circuit overload, have it corrected by a qualified electrician. If problem is a power outage, call electric company.
Water supply faucets are not turned on. Turn on water supply faucets.
Motor is overheated. Washer motor will stop if it becomes overheated. It will automatically restart after a cool down period of up to 30 minutes. (If washer has not been manually turned off.)
Washer door is not completely closed. Close door completely. Or try contacting Electrolux at 1-800-944-9044 Mon- Fri 8:30 AM- 8:00 PM I hope this helps some.
Mabye there is something keepin the door open, thats usually why most washers dont start
Hi - Could you please press and hold the start/pause and cancel button together at the same time for approximately 30 seconds? What error code does it display? With this information I can assist you further with the issue that the washer is having.
Diagnostic test
Electrical power cord may not be plugged in or connection may be loose. House fuse blown, circuit cradle tripped, or a power outage has occurred. Water supply faucets are not turned on. Motor is overheated. Washer motor will stop if it becomes overheated. Washer door is not completely closed.
