Clarion VX409 Car Video Player Logo
A
Anonymous Posted on Dec 04, 2013
Aux ord plug - Clarion VX409 Car Video Player
What type of plug is on alexa's auxillary output
Aux Input and Echo Devices
Aux input requires a 3.5mm auxiliary cable and a device with aux output capabilities. You may recognize the aux cable as the same type of plug that comes on a standard pair of headphones. An aux input amplifies audio from the output source.
De printer vraagt cartridge, ik versta niet wat hij bedoelt?
Hi
This is an english site, if ou can explain me the situation in english i'll help you :)
Need to know what iI orded on may the 16
Robert Acton, I checked at the Amazon web site. They do not sell the item #HT8645300 you mention. Perhaps they sent you a purchase order or a contact number.
3helpful
1990 ford telstar tx5 AT 2.2lt fuel injected motor
Is the spark plugs getting spark? Is it getting fuel?
2helpful
6answers
Can emc ax150 work without the UPS cable?
I moved my AX-150 to a location that would not allow me to install the UPS as it has redundant power/UPS and you should not connect a UPS to the output of another UPS.
Without the UPS the AX-150 forces the Write Cache to be Disabled. Performance drops, form what I have tested, to around 25x slower. This is due to not just turning off the controllers write cache, but as with ALL RAID controllers, the onboard drive 8/16M write cache is disabled as well so the drives are even slower then they would be if they where not used on a RAID controller.
The write cache disable is your real killer! Actually the write cache is disabled one a week while the REQUIRED battery test is performed.
My solution was to write an APC SmartUPS Serial Emulator that talks to the AX-150 telling it that the UPS is working fine so the write cache never gets turned off, including during the weekly battery test!
Here is the needed RJ45 to DB9F. Colors are base on someone cutting off the end of a cat5 patch cable.
You can find the APC SmartUPS commands off the web.
Communications capture:
Normal Comms from/to AX-150
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
!!! Weekly Batt Test Time !!!!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
W >> !! Tests battery, like pushing the test button on the front panel
OK<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
X >> !! Self-test results
OK<0D><0A>
l >> !! Low transfer voltage
097<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
n >> !! Get Serial number
AS0632112344<00><0D><0A>
R >>
BYE<0D><0A>
!!! End of Test !!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
I would be happy to share the Delphi source and EXE with anyone that would like to use it. Do not see a place to attach files here.
Can give you snapshot of main command-response logic:
if Result = pmerGood then
begin
tRx := Engine.RxString;
if cbHex.Checked then
Msg(Engine.SeeBytes(tRx)+ ' >> ' + #$0D + #$0A)
else
Msg(Engine.SeeChars(tRx)+ ' >> ' + #$0D + #$0A);
PendingCmd := '';
Engine.CharDelay := 0;
CmdData := 'NA' + #$0D + #$0A;
if length(tRx) > 0 then
case ord(tRx[1]) of
$01 : CmdData := 'Smart-UPS 750 RM' + #$0D + #$0A;
$1A : CmdData := '#uD43127130133136uA43108110112114uI43253257261265uM432252292' + '33237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e47200153045607590oD13120oA13100oI33230240220oM13208s431HMLq4820205081114172023p483090180270360450540630000k4310TNr483000060120180240300360420E443336168ON OFF' + #$0D + #$0A;
ord('A') : CmdData := 'OK' + #$0D + #$0A;
ord('B') : CmdData := '27.40' + #$0D + #$0A;
ord('C') : CmdData := '016.2' + #$0D + #$0A;
ord('D') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('E') : CmdData := '336' + #$0D + #$0A;
ord('F') : CmdData := '60.00' + #$0D + #$0A;
ord('G') : CmdData := 'S' + #$0D + #$0A;
ord('I') : CmdData := 'FF' + #$0D + #$0A;
ord('J') : CmdData := '0F,00' + #$0D + #$0A;
ord('K') : CmdData := 'OK' + #$0D + #$0A;
ord('L') : CmdData := '126.7' + #$0D + #$0A;
ord('M') : CmdData := '128.1' + #$0D + #$0A;
ord('N') : CmdData := '125.2' + #$0D + #$0A;
ord('O') : CmdData := '113.0' + #$0D + #$0A;
ord('P') : CmdData := '000.0' + #$0D + #$0A;
ord('Q') : CmdData := '08' + #$0D + #$0A;
ord('R') : CmdData := 'BYE' + #$0D + #$0A;
ord('S') : CmdData := 'OK' + #$0D + #$0A;
ord('U') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('V') : CmdData := 'FWD' + #$0D + #$0A;
ord('W') : CmdData := 'OK' + #$0D + #$0A;
ord('X') : CmdData := 'OK' + #$0D + #$0A;
ord('Y') : CmdData := 'SM' + #$0D + #$0A;
ord('a') : CmdData := '3.!$%+?=#|.' + #$01 + #$0E + #$1A + ''')+-89>@ABCDEFGKLMNOPQRSUVWXYZabcefgjklmnopqrsuxyz~' + #$0D + #$0A;
ord('b') : CmdData := '615.3.D' + #$0D + #$0A;
ord('c') : CmdData := 'UPS_IDEN' + #$0D + #$0A;
ord('e') : CmdData := '00' + #$0D + #$0A;
ord('g') : CmdData := '024' + #$0D + #$0A;
ord('f') : CmdData := '100.0' + #$0D + #$0A;
ord('i') : CmdData := 'FWD' + #$0D + #$0A;
ord('j') : CmdData := '0375:' + #$0D + #$0A;
ord('k') : CmdData := '0' + #$0D + #$0A;
ord('l') : CmdData := '097' + #$0D + #$0A;
ord('m') : CmdData := '08/03/06' + #$0D + #$0A;
ord('n') : CmdData := 'AS0632112344' + #$00 + #$0D + #$0A;
ord('o') : CmdData := '120' + #$0D + #$0A;
ord('p') : CmdData := '090' + #$0D + #$0A;
ord('q') : CmdData := '02' + #$0D + #$0A;
ord('r') : CmdData := '000' + #$0D + #$0A;
ord('s') : CmdData := 'H' + #$0D + #$0A;
ord('u') : CmdData := '127' + #$0D + #$0A;
ord('x') : CmdData := '01/01/10' + #$0D + #$0A;
ord('y') : CmdData := '(C) APCC' + #$0D + #$0A;
ord('z') : CmdData := 'CLEAR' + #$0D + #$0A;
ord('9') : CmdData := 'FF' + #$0D + #$0A;
end;
if CmdData <> '' then
begin
Msg(Engine.SeeBytes(CmdData)+ #$0D + #$0A)
else
Msg(Engine.SeeChars(CmdData)+ #$0D + #$0A);
Engine.SendMsg := CmdData;
end;
Bob A. Hay
1helpful
Firing orde ford 6 cyl f-150 truck distributer to spark plugs
you didn't say if you have the straight 6 or v 6.But i'll give the order for both.
The 4.9L straight 6 is 1-5-3-6-2-4----------- distributor rotor turning clockwise, and #1 plug is the first plug.
On the 3.0 and 4.2 V6 engines is 1-4-2-5-3-6-------#1 plug is the first plug on driver side---- facing engine.
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
